where's my boost?? flux2.5,stacked,and64/14 40psi
Old May 27, 2008 | 12:11 AM
sitdownsteve's Avatar
ok so when i ran bd and quad stacked stock injectors 37psi, then stock but with the flux 2.5's 35psi, then flux's and quad x2 race on kill 42ish rail 25,26,000 all day long, now bully dog, flux's 39/40 psi rail 24,000, bully dog quad stacked same 39/40 rail 20/21,000 all was with the 64/14 and wastegate closed so i am going to dyno this week also but i figured i would see more boost, also i think it felt faster with the x2 only on kill... what do you all think
Old May 27, 2008 | 03:00 AM
Speed Shift's Avatar
Looks to me like you are running out of CP3.
Old May 27, 2008 | 09:44 AM
yeah i think so too, but still i think i should have alittle more boost
Old May 27, 2008 | 06:04 PM
bluechrome's Avatar
Wheres the Waste gate at?
Old May 27, 2008 | 07:43 PM
mainiac's Avatar
stock wastegate for htt turbos is 40 psi. my 66 sees 42 at wot. if you can reach the wastegate shaft, screw it in to make it shorter to hold wastegate closed longer....not easy to reach though. make sure head studs are in for more than 40 psi.
cincydiesel
Apr 8, 2009 01:34 PM
lowboy18011
18
Dec 1, 2006 06:46 PM
RockGuy82
Aug 31, 2006 12:00 AM
rshelton88
Mar 20, 2003 07:14 PM
BJK
Jan 9, 2003 02:41 AM
