Wheres the best place to tap into lighting power for gauges?
Where's the best place to tap into the wiring for the gauge lights. I'm thinking past the cluster dimmer, that would allow them to work off the same circuit and be controlled by that dimer. Anyone that has done it this way I'd like to hear the easiest way to do it.
Thanks
Thanks
if you're installing your gauges in your center console when up pull out the face plate there is a wire connection for an optional light that only work when the headlights are turned on which easily supplys a ground and your +12v lighting i then tapped the lighter circuit for the +12vit made it pretty easy
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
APD
Mar 7, 2005 06:48 PM
