Wheel Question
Old Jun 23, 2005 | 11:52 AM
CrashCade's Avatar
If I were to do that sme lift, I would look at the 4.5" Backspacing. The 6" back spacing is going to sit to far in the fender for a decent Off-road look. Try to find some pictures to refer to. Most of the lifted trucks you see running around in CA are running the 4.5" backspacing.
Old Jun 23, 2005 | 12:03 PM
cquestad's Avatar
Get the 18x9.5 with 6" BS. The first wheel will stick out 2" (because of the 2" less backspacing than stock) + 2"to 3" (because of the 2" wider wheel plus tire) for a grand total of 4-5" outside of where your OEM tire is now. YUK!
1/3 or so of your tire will not be under the truck!
IT will also not work with the lift....will stricke the front and rear of the front fenders when turning.
The 18x9.5 will be right at the limit.
I would run the 18x9.5 with 6" BS.
Old Jun 23, 2005 | 02:56 PM
CrashCade's Avatar
I believe this is a 5.5" With 20x10. I am not sure it belongs to WhiteSport600
The Boss Hog
Mar 29, 2003 10:37 AM
bryan5791
Mar 3, 2003 06:11 PM
waam
Jan 4, 2003 06:53 PM
jet
Dec 15, 2002 08:11 AM
Teddy
Nov 2, 2002 01:56 AM
