whats a good combination for power?
Old Feb 27, 2008 | 11:07 AM
mm73's Avatar
Yall can see what I have in my sig, I am thinking of getting some injectors and a turbo but I need a few ideas on what to start looking at. I would like to have 90 hp injectors to add to the mix and a 62/12 but I am not sure on two things. 1. is that the right size turbo or should I go bigger? (I dont dog my truck out the quad is ussually off except when I want to play and the smarty is always on 90 to) And 2. If I was to get injectors would the cp3 pump be able to keep up? Oh I have my trans built now and a fuel system I just forgot to put it in my sig. Thanks for any input.
Old Feb 27, 2008 | 12:18 PM
tristan21's Avatar
With a smarty alone if you crank it you will drain your rail and power will drop off. For around town driving you will be fine. Sounds like on the turbo if you just wanna play a little then you will be good maybe a little small could get warm. I would suggest a bigger turbo if you put it all to more use than 90hp settings.
Your real concern should be stock fuel system and tranny. If auto get a tc and vb and if std. get a con fe.
Old Feb 27, 2008 | 02:27 PM
mm73's Avatar
thanks I appreciate it. I just want to know that if i want to turn things up, that i wont be damaging anything due to heat or not having enough air with the fuel. I guess just tryin to get the air to fuel mixture right. thanks again
W150CTDproject
Jul 9, 2009 12:22 AM
cvcook
Feb 18, 2007 09:16 PM
Math_Teacher
Apr 26, 2004 04:22 PM
GIT-R-DONE
Mar 22, 2004 02:35 PM
wv smoker
Feb 2, 2004 04:59 PM
