What should I stack With EDGE EZ?
Old Feb 1, 2006 | 09:06 PM
2500WHITERAM's Avatar
OK gentlemen...
On My 2003 HPCR, 555, I have and Edge EZ...it works well with the 5" turbo back exhaust. My question is......whats going to be the best "stackable" upgrade match for the edge EZ?
What would you guys recommentd?, and why?
Thanks in advance....
Old Feb 1, 2006 | 09:45 PM
CATCRACKER2's Avatar
tst and turn down the ez to 2 or below to save fuel system. ie cracking injector tips etc.
Old Feb 1, 2006 | 11:39 PM
hognutz's Avatar
timing and duration box.
tst powermax would be my pick ans the 03 juice adds fuel pressure ast well. I think the tst is just timing and duration.
now if you feel edge loyal you could call them and ask what kind of pressure the 03 juice does and if that is smart to stack. I think I have seen people doing it. I personaly would not cross stack parameters. this does not mean it can't be done I just would want more control than that.
Old Feb 2, 2006 | 09:59 AM
HP Upgrades's Avatar
If you dont go with the TST, I would also suggest looking at a Predator or Bully Dog programmer. It will stack really good and give you plenty of parameter adjustability as well.
The Predator will give you 120hp and 240 ft lbs or torque, and the Bully Dog can come either as a Triple Dog at 140hp and 209 ft lbs or torque or as a Power Pup with 130hp and 250 ft lbs of torque.
Very easy setup and they will allow you to diagnose trouble codes as well.
Old Feb 2, 2006 | 10:05 AM
I was contiplating the bullydog progarmmer myself. I just think it will be trial and error as far as combination setup. Without a dyno handy, It will be kind of tough deciferering the best combination. I know the edge is increasing line pressure. what does the power pup physically adjust? pump timing,???
Old Feb 2, 2006 | 10:26 AM
pullin hard's Avatar
i was told timing and duration, and some pressure on extreme. my pup works great, very good programmer, good feel in power, and the extreme is very aggressive, which i like . i also run the Quad box, not as aggressive in the higher settings, but also a great box.the problem is that i can't stack these 2 boxes together, which one will be for sale, as i also bought a Edge EZ box to stack with which ever. the only thing you must decide is do you want to change on the fly, or can you wait and down load your program???
Old Feb 2, 2006 | 11:18 AM
Agades's Avatar
I would definately NOT stack a programmer or any box that does anything to pressure together with another pressure box (in this case edge EZ).
Don has already proven that the EZ itself has the ability to cause damage to injectors
TST or Van Aaken 3.2
timing and or duration only
the juice adds pressure also on the 555 motor
I believe the predator does pressure? so that also would be a bad stack
Old Feb 2, 2006 | 01:18 PM
wileyc's Avatar
I would use either the TST or the van Aaken C3.2. The C3.2 with the Rokktech sensor works very well.
Old Feb 2, 2006 | 02:17 PM
MR4WLR's Avatar
I'll give another vote for the TST, they really work well together.
Old Feb 2, 2006 | 04:39 PM
043500QC's Avatar
I`ve got a Bully Dog Power Pup stacked with my EZ. I really like the combo, my mileage went up almost immediately once I added the EZ. The TST/EZ stack is a very popular combo too.
Old Feb 2, 2006 | 06:08 PM
fgrdods's Avatar
I have the TST and the EZ (setting 2) stacked. I am pleased with the setup. Regardless of what component you add next, you will soon have to address your fuel system and tranny. Niether were designed for the amount of power or torque. Don't get me wrong, you can get by with stock for awhile, but you won't be able to use all the power effectively without causing other problems. My tranny is next...
Old Feb 2, 2006 | 06:57 PM
OK.
I opted for the BullyDog Power Pup programmer.
Im going to take care of tranny myself...thats no problem.
What do you think I need to do to address the fuel problem?
You guys are the best...keep firing at me!!!
Old Feb 2, 2006 | 09:50 PM
043500QC's Avatar
OH LORD, thats a loaded question around here.
Old Feb 3, 2006 | 08:55 AM
lol...OK SQUEEZE THE TRIGGER !!!
AND IF YOU SUGGEST THE "POS" FASS, ILL PUKE...WHAT A WASTE OF $$$
59c
Jul 22, 2010 06:15 PM
VikingDiesel
Nov 15, 2006 12:24 AM
smoky beast
Oct 18, 2006 06:58 AM
B.Law
16
Apr 22, 2005 02:28 PM
Cat Cracker
Jul 14, 2003 12:17 PM
