What should come first turbo or injectors
Old Jan 19, 2008 | 02:18 PM
drewblood's Avatar
Just put a SB DD in the truck and have a little bit $ left over and would like your advice as to what to do next can afford inj's now but will need a couple months tilll ive got enough for a turbo do i wait for the turbo or put inj's in now
if inj's first which ones don m of corse but 1. 1.5 1.8 2.0?
if turbo first which one twins are out unless under 2'g's
Old Jan 19, 2008 | 02:34 PM
gus's 03's Avatar
its kindof a catch 22...
id say turbo first. the only down side you'll see is slower spool.. then when you throw injecters on you'll have no worrys.
if you do injectors first, you wont get the full bang for the buck and it'll be hotter..
im assuming since you went dd your looking to make farily big power? 600+?
Old Jan 19, 2008 | 02:42 PM
drewblood's Avatar
hp in the 500s is my goal and not to be turning day into night arround town found this torbo in the classifieds would this due the trick
SPS 62-71-14 turbo dont want a coal train so will this spool close to stock if i can get this one i could afford flux 1s also at the same time
Old Jan 19, 2008 | 02:50 PM
oscaroc's Avatar
i did injectors first, mach 4, still very driveable
Old Jan 19, 2008 | 02:56 PM
gus's 03's Avatar
then grab the turbo, and injectors, turn the boxes down a bit and you'll probably be happy in the mid 5's.
<edit> actualy, sell the ez, that'll hellp ya re coupe some of the expense and run with a better margine of safety prob do a set of flux 1.5's<edit>
Old Jan 19, 2008 | 06:57 PM
Justice4all's Avatar
Turbo first! Your stock injectors will easily support 500 HP and if this is your goal there is no need for injectors yet, but your stock turbo definiltely needs to go. The SPS 62 is a great place to start.
Old Jan 19, 2008 | 08:53 PM
drewblood's Avatar
is the turbo describe above a senseable turbo or is it over \ under kill for my set up
Old Jan 20, 2008 | 01:14 AM
The SPS 62/14 would be perfect for low to mid 500's. Step up to the Silver 62 for mid to high 500's. The stock injectors will hang in there for quite a while. If you decide you need injectors the Flux 1's or 1.5's would be great, but not necessarily needed just yet.
Old Jan 20, 2008 | 02:36 AM
Luvnacumns's Avatar
Agreed!!!!!!
Old Jan 20, 2008 | 11:20 PM
drewblood's Avatar
thanks for the respones ill go with the turbo is buying a used turbo ok it seems kinda wierd ya know such a big purchase on a used product is used 6000mi ok what would you guys think
Old Jan 20, 2008 | 11:47 PM
kantdrive55's Avatar
DTR Advertiser
What do you do with the truck? If you tow and tow heavy that is something to take into consideration when pricing out a turbo. You dont want to go to something that wont tow very nice, if that is what you do with the truck. If it is just a street driven toy that only pulls the boat every once and a while, then you can afford to give up a bit of that bottom end for that top end flow. Even though it sounds kind of funny, you can have 500hp feel completely different from one turbo to the next. Dont just get into something because it is a good deal. It might be a good deal, but if it isnt the right turbo, then the deal really isnt that good.
Try and drive a couple of different brands of turbos. Try our turbos, try the HTT turbos try Industrials then try and form your own opinion.
My vote would be turbo first. No sense having the extra fuel there if you cant use it.
Old Jan 20, 2008 | 11:51 PM
drewblood's Avatar
thanks kd55 for the sound unbias advice
redsealdodge
31
Dec 7, 2007 05:22 PM
Patrick Campbell
Jan 20, 2004 09:02 PM
