what fuse to tap into....
If your talking about for the lights then I would use the trailer lights fuse not sure what number it is and for the pyro power you want something that comes on with the key. If you take the lid off the fuse box under the hood all the fuses are listed on the underside of the lid.
For the lights to dim or brighten on the gauges, you can pull off the panel with the light switch on it. Look at the bottom of the plug in and there is an orange/brown striped wire in the center.(only two rows of wires, 3 on top 2 on bottom) That is the dimmer and light control, you can just tap into that. That is how I did the lights, but the rest was done as described above, for the actual power going to the pyro to make it work.
Mike
Mike
Originally Posted by carcrz
why not just use a blank in the fuse panel? That's what I did w/ my snow plow. There should be a couple of spare fuses in there.
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
bgilbert
Mar 2, 2006 04:01 PM
