Westach Gauges??
Westach is great for a 6 speed truck. I read some test (TDR maybe) comparing Westach, Isspro, DiPricol, etc. I think they were all accurate. But the Westach was the fastest. I think it said that the Westach took less than a second to read accurate, where the Isspro (what I had before the westach) took quite a bit longer.
I pulled this all out of my impaired memory, so yhou should check it out yourself.
I definitely noticed that my truck did not run as cool as I thought it did when I went from to my Isspros to my Westach. On a stick shift, with such a short RPM range, I believe I would be off the throttle and shifting before the Isspro EGT gave me an accurate reading on the WOT EGT was. It may have been just too slow. If I recall the test accurately, it was like 3 seconds for the Isspro to give an accurate reading.
FYI
FYI
Dodgezilla
Sep 21, 2009 04:35 PM
SJ21XDC
May 3, 2007 08:45 AM
coontz0473
17
Sep 22, 2006 03:52 PM
rjm022
Jan 30, 2006 07:53 PM
