Well, apparently I got the 51" Nelson muffler w/a baffle
I called my local Fleetpride dealership and gave them the 51" Donaldson p/n and they crossed it over to the Fleetpride p/n of M4490 (Nelson equivalent). Ok, I went to pick it up and it has the baffles in it.....I thought no big deal.
I installed the muffler, then came on DTR and discovered that I apparently got the incorrect muffler
I then went to Cummins Filtration's website to compare flow rates of the Nelson w/baffles -vs- the non baffled Nelson. Anyway, the baffled Nelson (86713M) flows 1450 CFM in 2 inches of mercury and 1750 in 3 inches of mercury. The non baffled Nelson (86131M) flows 1670 CFM in 2 inches of mercury and 2000 CFM in 3 inches of mercury.
Ok, here's my question.....does it really matter with a stock truck if it flows at the lower CFN numbers (baffled Nelson) -vs- the slightly higher CFM numbers (non-baffled)? My main goal is to remove the restrictive stock muffler and reduce EGT's.
.I then went to Cummins Filtration's website to compare flow rates of the Nelson w/baffles -vs- the non baffled Nelson. Anyway, the baffled Nelson (86713M) flows 1450 CFM in 2 inches of mercury and 1750 in 3 inches of mercury. The non baffled Nelson (86131M) flows 1670 CFM in 2 inches of mercury and 2000 CFM in 3 inches of mercury.
I'm probably overreacting to the whole baffle thing anyway. I'm certain that in order for it to ever be viewed as restrictive I'd have to add quite a bit more power. By that point, I'd probably need to move to a 5" turbo back system anyway
Jbremount
0
Sep 8, 2014 01:05 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
8mpg
May 11, 2006 09:28 PM
draebi
166
May 3, 2006 12:05 PM
lightening ram
Nov 16, 2004 09:22 PM
