Weird whats up?
Old Nov 12, 2009 | 11:12 AM
zack birge's Avatar
Exclamation Weird whats up?
Ok the truck in my sig, had done this twice in the past month. It starts, then after 5 seconds it dies. No codes, And it does it twice then is fine. If I give it a little fuel it is fine! Whats goin on with this?
Old Nov 12, 2009 | 08:09 PM
1985cucv's Avatar
do you have the stock lift pump?
Old Nov 12, 2009 | 08:25 PM
zack birge's Avatar
No Raptor 150 gph in signature
Old Nov 12, 2009 | 08:44 PM
Spooler's Avatar
Sounds like it is the security system causing it.
Old Nov 12, 2009 | 09:09 PM
gear jammer 91"'s Avatar
My truck did something similar the other morning. It fired once and then died. It did this three times, and then I gave it some throttle and it started just fine. It hasn't done it since? My truck doesn't have a security system. My lift pump has been replaced by the factory, it's in the tank now, and the fuel filter only has 2K miles on it. No codes either. I didn't check for soft codes though.
Old Nov 14, 2009 | 02:28 AM
buzzard1's Avatar
My 06 does this from time to time and ended up being a problem with the key (sim key or whatever it's called).
Nick & Kels 08
Nov 16, 2010 07:49 AM
Common
Apr 9, 2008 10:25 PM
The Domie
Jan 6, 2005 02:23 AM
jman4567
Apr 22, 2004 10:15 AM
spassey
Jan 25, 2003 12:08 PM
