Head Studs?
Old Nov 14, 2009 | 10:47 AM
Redsmoke's Avatar
Head Studs?
Hello
My truck is at Jazzy Diesel due to one of the injectors going dead. So on monday there going to fix that problem and while they have opened up the Valve cover and taken the injectors out, I ask them to throw in a pair of Dyamite Diesel 90hp nozzles. Might as well take advantage of the labour.
My question is, Since they already have opened up part of the motor, can the do head studs with out replacing the head gasket. OR is they any other mod i should consider while they are working on it. Please keep in mind that i will be get PDR Cobra stage 3 twin turbos. supers300/HT3B
Please post up!!!
Old Nov 14, 2009 | 12:15 PM
Stovetop535's Avatar
Yes they can do head studs without replacing the gasket. If you want to save on labor I would put a set of springs in along with the studs and injectors. The injector has to come all the way out to do the springs. Might as well while they are in there!
Old Nov 14, 2009 | 12:22 PM
dodgediesel's Avatar
Let me know if Jazzy will do the studs without changing the headgasket if you don't mind? Thanks Redsmoke...
Old Nov 14, 2009 | 02:30 PM
Redsmoke's Avatar
yeah i let you.
12valvetom
Nov 27, 2009 11:37 PM
dieselboy59
Jan 30, 2009 03:57 PM
smokewagon
Aug 8, 2008 09:54 PM
MikeThomas
May 11, 2008 11:39 AM
jmccart
21
May 14, 2007 11:47 AM
