weird problem???
Old Jan 29, 2007 | 11:37 PM
desertram800's Avatar
weird problem???
Ever since I installed my outlook monitor I get a code every so often (mabye like once or twice a week) that says ECM COM error. Anyhow, I use my powerpup to clear it, and it's fine. Today I started her up, started driving and noticed that it seemed to have no power, well the CEL came on so I pulled over and checked it. It was the same ECM COM error code, so I cleared it, the CEL went off and I drove home. However, on the way home, I noticed that my turbo whine sounded louder than usual, and my outlook monitor was showing it running at like 17-20psi cruising at 70 and even slight throttle increases would shoot it to 30-38psi. Also, RPMs were normal, so I'm not missing overdrive. Normal cruising at 70 before I think was right around 8psi. Anyone know what's up???
Old Jan 30, 2007 | 08:36 AM
CButler610's Avatar
bad Outlook/bad harness/wiring fault
Common
Apr 9, 2008 10:25 PM
Strjock81
Jan 24, 2005 07:54 PM
jman4567
Apr 22, 2004 10:15 AM
jrs_dodge_diesel
23
Mar 2, 2004 06:32 AM
turbospl311
Oct 14, 2002 08:23 AM
