Weird boost issue
Old Apr 6, 2008 | 03:20 PM
northernwheeler's Avatar
Weird boost issue
Ok, heres whats happening. Sometimes when i am cruising down the highway (65mph) and floor it, my boost only gets to about 30 psi and then my egts start climbing pretty high. After I had first installed the XZT I could get it to hit 42 really easy.
Now what is really strange is that it only does it some of the time. i can floor it and it won't build more than 30 psi, then i will try again in 30 seconds, and it will build to 42-43 no problem and my EGT's stay low. If I set the XZT to level 1 or 2 it will build boost no problem and be consistent, but soon as I put it on 3 it really struggles to get above 30.
Is this a sign of a larger problem, or could it be a problem with my XZT? I am kind of hoping somebody else has had this issue or can give me an idea on what to do?
Old Apr 6, 2008 | 03:30 PM
jgiachino's Avatar
Fuel / Rail Pressure? Do you have a pressure guage?
Old Apr 6, 2008 | 03:32 PM
Rail pressure stays ok, Fuel pressure drops to about 1 under hard accreleration, but it did that from when I first installed it until now, which is about a year, maybe a bit more.
Old Apr 7, 2008 | 05:28 AM
tesla440's Avatar
Put a clamp on the hose going to the waste gate actuator. It may be a bad waste gate activation solenoid.
Old Apr 8, 2008 | 10:24 AM
I will give it a try.
Old Apr 8, 2008 | 10:33 PM
Snapoff's Avatar
Does the Quad box de-fuel when it senses a slipping transmission?....Just a thought, but something you need to know (before things get expensive).
Old Apr 8, 2008 | 11:05 PM
Spooler's Avatar
Nope, it does no defueling. At least my X2 dosen't.
Old Apr 9, 2008 | 01:05 AM
wardy70's Avatar
I had the same problem out of my 06 and it was the waste gate actuator. I clamped it off and had all kinds of power
Old Apr 9, 2008 | 10:39 AM
I haven't had a chance to look at it yet, work has been crazy busy, but the way it does it sometimes, and then it is fine for a while, then acts up again makes me think the suggestion about the wastegate could be the problem.
The only thing I don't understand is why it would be worse when the XZT is on #3 compared to when it is on #1 or #2?
Old Apr 9, 2008 | 11:38 AM
Convicted1's Avatar
Sounds like the same thing my truck used to do with just the smarty..
Does this unit do Boost Fooling?? If not you may need to buy a boost fooler..
I could be completely wrong though...
Old Apr 9, 2008 | 05:42 PM
Yeah, it does boost fooling. For some reason, it has been working fine all day, lots of power, boost builds quick. I am going to check that waste gate as soon as possible though.
Common
Apr 9, 2008 10:25 PM
Gotlift01
Sep 4, 2007 09:00 AM
jimc11
Mar 28, 2006 09:20 AM
96RAM
Mar 13, 2006 01:04 PM
Jack Thorpe
19
Jun 27, 2003 07:56 AM
