Weak Front Suspension?
I have an '06 3500 4X4 CTD. Anything I should know about the front suspension?
Seems like it "bottoms out" a lot. I can go over a speed bump (slowly), and when I come off of it, the front bottoms out. When I go over some dips in the road, it bottoms out. I might have 60lbs of accessories on the front . . . shouldn't make a difference on a 3500. Thoughts?
Ive never had that problem, when stock. Not a 06 though, but dont think there is a big difference.
Does not look like you have a lift.
What makes you think it is bottoming out, noise, contact, ride?
I can feel it "hit" the frame or the stops. I don't have a lift . . . just stock 4X4.
I know my truck is a few years older, but I think the 3rd gen. suspensions are pretty similar. I have wheeled the heck out of my truck, hitting ruts hard enough to get both fronts off the ground and haven't had bottoming out problems. Take it to the dealer.
I replaced my stock springs with ones that are 2" longer (same spring rate), and that fixed the problem.
Where did you get those springs and how much?
My 2500 hits the stops as well on every speed bump it isn't harsh you can just feel the suspension end. It feels like there is only 3-5" of spring......
Around $300 shipped (they're heavy!).
I know Skyjacker also sells taller springs which are cheaper (around $200), but Ive heard multiple times that they tend to sag prematurely.
. How hard were they to put on? I've never put springs on before . .have done plenty of shocks. My F450 had leaf springs in the front.
Thanks . . . I might have to look into that. I'll have to say, that is my first disappointing find on the truck so far . . . well . . . besides the horn and the lights flashing when I put it in reverse with the door open
. How hard were they to put on? I've never put springs on before . .have done plenty of shocks. My F450 had leaf springs in the front.Thread
Blessed
Feb 14, 2007 10:31 PM
fsixrider
Nov 27, 2005 08:08 AM
Ripper406
Dec 14, 2004 07:45 PM
