Water injection question...
I am looking into a water injection kit, but wondering if straight water increases cylinder pressure???
I am on a quest to see how far I can go on stock HG and untouched bolts. I don't want something that increases cyl pressure artificially.
What way to activate works better??? I.e. Boost or EGT
Yes plain water will increase cylinder pressure as you are artificially increasing the mass of the air charge.
It depends. If you see a power increase, you can see a slight pressure increase. Typically, pure water injection systems like the smaller kits dont add cyl. pressure, but rather slow combustion down some to lower peaks. Adding methanol goes the other way, raising peak spikes.
gsbuick65
17
Aug 3, 2009 01:41 PM
GOT BOOST?
Apr 18, 2009 10:05 PM
jdpiii
Jun 19, 2008 07:34 AM
Rpainter
Jun 14, 2008 12:09 PM
deezulsmoke
Aug 29, 2005 03:04 PM
