Water H2o / METH ?***
Been Considering this as my next stage of Mod for my Truck, Getting Ready to install my Edge EZ, to stack with my Hot Juice, Figured the Snow system may help lower egts a bit while adding a little HP
perhaps?
Anyhow I like the benifits of the Stage #3 Kit , But Do not need the Guages portion of it and would be paying for somthing I do not need. Is there a kit that provides the Benifits of a stage -3 Minus Guages. I also have a Joe Hellmann Intercooler on the Way anxious to see how it performs. Hope to cool things at least a 100 degress over current Temps, Water / Meth systems seem to advertise
40-- 70 rwhp increase pending truck set-up any idea what I can expect from a stage -2 --- Stage#3 Kit ?
How often does One have to Re-Fill Tank with Fluids for the Unit? on Average a Month for Daily Driving use and a couple Hot Launches within the Month Too. Just wanted to make sure it was somthing I did not have to worry about filling up every other Day.
Anyhow looks like some units Come with a larger Resivoir Design, What are the best performing units out there. I see ATS has theres , along with the Snow system.
perhaps?Anyhow I like the benifits of the Stage #3 Kit , But Do not need the Guages portion of it and would be paying for somthing I do not need. Is there a kit that provides the Benifits of a stage -3 Minus Guages. I also have a Joe Hellmann Intercooler on the Way anxious to see how it performs. Hope to cool things at least a 100 degress over current Temps, Water / Meth systems seem to advertise
Cooling Mist is another one. CM probably has the best controllers out there.
Whichever system you go with just be sure you use a solenoid or a checkvalve with a preset cracking pressure to prevent siphoning water into your motor when it's not running. I think CM and Devilsown kits both come with good checkvalves. For some reason Snow doesn't seem to inlcude one. They rely on the pump to prevent siphoning but that's not the best way of going about it (for a couple reaons).
I have the devilsown and it is great kit, but I don't care for the controller, so if I had it to do over again, I would get the devils kit with out the controller and use one that is egt based rather than boost. I also used the stock windshield washer tank because it has a built in low warning, and I fill mine about once a month, but I also don't drive around with it floored.
Water / Meth
Great Point!
You have there and I appreciate it "EGT " Controlled dispersment, as this is when you Really want it to inject, Ok so the Devils Own Kit , minus the Boost controlled system,
What system or method will work with devil own for an EGT Controller Combo?
Or is there another System out there that is Just EGT Controlled, I Guess I am Stuck getting one of the level #3 Kits that come with Guages already as to perform the most effiently with Power Mods So what would be an Ideal Setting For the unit if You were driving around
Town and the HWY and wanted it to Fill The Benifit , without being in Race Mode as to empty the Tank in a Day.
Driving with just the Truck No- Load No- Towing just for Fun. I have a Joe Hellmann after market Intercooler should be showing up at my door later this Week, And Figured the Water / Meth system will provide the ultimate combo for EGT Control, hence more Power and some increased fuel economy, And Longer Engine Life do to less engine heat and friction.
I use the Devils Own boost setup and love it. I wouldn't want an egt based injection because I can see 1000 degrees easy with very little boost and wouldn't want to inject water under such a low boost condition. I have mine set to go on by around 15psi and full at around 30psi. Works very, very well...
tristan21
Dec 28, 2006 07:01 AM
blackdiesel
19
Nov 14, 2006 03:54 PM
BigBully
Feb 16, 2005 06:19 PM
