Pictures of where to Install H2O/Meth Nozzles
Anyone have pictures of where to install The nozzles on a Snow Stage II kit? And also what are you running in it? Straight washer fluid? Deluting it?
Cool Thank you Jimmy. I was thinking more on the Manifold itself or one on each side of the intake. Is there a reason to have both on one side? I Have had this kit since last summer and have yet to open it up and look at it. this weekend is intercooler, HTT STage IV and Water/Meth jection. I Think Im gonna Break The input shaft
I put them both on the same side of the elbow so the two spray patterns wouldn't spray at each other and possibly cause larger drops to form. Also made the plumbing cleaner.
If you put them down in the cover plate on the head the center two cylinders won't get any water/meth because it's not going to flow upstream.
I run 50/50 water/methanol.
You are gonna love this stuff.
If you put them down in the cover plate on the head the center two cylinders won't get any water/meth because it's not going to flow upstream.I run 50/50 water/methanol.
gus's 03
Jul 9, 2007 12:12 PM
tristan21
Dec 28, 2006 07:01 AM
blackdiesel
19
Nov 14, 2006 03:54 PM
