Waste Gate Stuck?
Old Jul 20, 2005 | 11:06 AM
Mopar_Mudder's Avatar
Waste Gate Stuck?
Ben having some strange sounds for my truck lately. I high pitch whissle at higher boosts and what sounds like a lot of air rushing out from under the truck. Also it will only make about 25psi of boost, running the EZ on 4 it use to do the low 30's.
I have check every rubber boot from the turbo to the intake a couple of times and can find nothing bad. So I crawled under the truck to see if their were anything that looked like leaks around the turbo and exhaust and nothing. Also I figured I would check out the waste gate while I was their and I can't get it to move at all, pried on it with a big screw driver and banged on it a little and it didn't move at all. How hard should it be to mave that thing, I figured I would be able to open and close it?
What would cause it to freeze up? I do run the exhaust brake alot in the winter to help with warm up, but I have never heard of this being a problem.
Old Jul 20, 2005 | 11:19 AM
WhiteSport600's Avatar
It's really stiff, you probably won't be able to move it while it's on the truck, Sounds like you just have a boost leak somewhere.
Old Jul 20, 2005 | 11:22 AM
Any EZ way to look for a boost leak, being you can't make boost sitting still?
It also run hot EGT's then it use to and blows black smoke that it never use to.
Old Jul 20, 2005 | 11:31 AM
Yeah, you definitely have a boost leak... I'd just start checking all the hose connections starting from the outlet of the turbo and following all the way to the intake elbow. Just start tightening the clamps. Sometimes they are a little too loose from the factory.
Old Jul 20, 2005 | 12:01 PM
Kramer's Avatar
The best way i've found leaks is to run the truck and use a spray bottle with soapy water. Check all the hoses and the charge air cooler. And like sport said check your clamps.
Old Jul 20, 2005 | 12:06 PM
Done that twice already......
Old Jul 20, 2005 | 01:19 PM
Mixer Man's Avatar
Spray that intercooler down could be one of the elbows leaking or a good rock hit might have knocked a hole in there . Good luck boost leaks can be a real bear to find ........... clean all the hoses and such real good and watch for the telltale signs of a leak .
Old Jul 20, 2005 | 06:37 PM
nickleinonen's Avatar
what was the engine speed??? try it with the engine sitting on the governor [brick on pedal]
it isn't going to harm your engine in any way as long as everything is up to temprature... there are some factory tests that require the engine to be at top idle...
Old Jul 20, 2005 | 10:24 PM
metal_miner's Avatar
Re: Waste Gate Stuck?
try hooking some regulated shop air to the wastegate hose to see if or at what pressure it activates the wastegate. Hope this helps!
Old Sep 12, 2007 | 05:37 PM
bramage's Avatar
Conclusion?
Did you figure out what the problem was? A truck I know of has the same problem and it does not have a boost leak.
Old Sep 12, 2007 | 05:51 PM
35" 05''s Avatar
plastic intercooler? Just a thought
Old Sep 12, 2007 | 05:55 PM
bramage's Avatar
Did, now banks, no boost leaks, noise comes out of tailpipe.
Old Sep 12, 2007 | 09:59 PM
bramage's Avatar
To the top please.
Old Sep 12, 2007 | 10:16 PM
vzdude's Avatar
DTR's 'Go to Guy'
Heard some guys talking about the gasket on the intake leaking near the back. A couple of bolts came loose and blew the gasket out. Not that I have seen it myself, just remembered reading it on here. What do the impeller blades look like? Any play in the shaft? Usually the wastegate gets stuck closed when it happens, so I would doubt that that is it, but which way were you trying to move it? Try it both ways. I can move mine with needle nose pliers kind of using them as a lever prying against the housing on the rod.
Old Sep 12, 2007 | 10:18 PM
cbrahs's Avatar
you can take the "C" clip off the waste gate and remove the rod to the side. it is a pain to get back on but you will be able to move the waste gate back and forth to see if that is your prob.
The_g10
Feb 13, 2013 04:45 AM
dochawken
Nov 27, 2012 08:55 PM
Baja
Jan 29, 2008 08:17 PM
whiteknight
17
Jan 8, 2003 10:38 PM
