Warranty question
Warranty question
Approximately 6 weeks ago I bought on '03 Ram 2500 CTD with 61K miles equiped with the Banks 6 gun (or so I thought). It appears that everything is still installed on the truck except for the actual computer itself. I'm not so worried about having use of the Banks system itself, but am now worried from what I've read on here that it may have voided the warranty on the truck.
It has now starting leaking a small amount of oil from the rear of the engine and I am worried about taking it to the dealer because the selector dial for the Banks system is still installed in the dash and I believe a wire going into the manifold.
Does anyone know if the dealer will look at this and immediately void the warranty?
Please Help!! Thanks.
The Bypass must be install NOW or your truck would not start, Just Remove all the wiring and harnesses.Any questions on the removal I will send you the Manual in PDF if you send your Email address to tcdieselperformance@msn.com. It will take about 1 hour to remove.
LFD2037
06-08-2008 01:36 PM
gandalf1g
11-26-2007 02:31 PM
trik396
05-30-2007 04:42 PM
