Walbro Pump pressure kit
Anyone use this kit to increase supply pressure? I have dual pumps and I believe I need more supply pressure for them.
The spring and washers cost $19.00. Does it work. The kit is sold by Glacier Diesel Performance.
Yes, it works. I went through the walbro for a while, I was thinking about getting duals, but went to an AD... I like the AD a lot better.
Instead of buying the kit, just get some similar sized washers and put in the bypass. You do have the brass bypass, right?
BTW, PM sent...
BTW, PM sent...
depends on how much more you are looking for. I pulled the bypass apart and stretched the spring some. I now have about 23psi so it went up about 5psi from that. It has maintained that for 6 months now.
streetsmoker
26
Nov 4, 2019 10:27 PM
A_Manke
Mar 24, 2007 04:21 PM
DmaxEter
41
Apr 17, 2006 07:11 PM
