valair on the way out
well i bought my 03 quadcab srw 3500 6spd 9 months ago had the stacks and chip with in a month then the stock clutch started going out so i was cheap and got a full feramic valair with the 3400 presure plate installed it and had problems for a month or so with it not fully disengageing then it work ok and held the power i had but i guess i was hard on it ie racing and offroading and now it has started slipping in 6th under hard accel. so i guess i and saving up for the southbend dualdisk that i am going to need some on top of going to school and $4/gal fuel prices can someone tell me which dd i need to get ????
from my first hand I went cheap on the clutch on my last truck and it was a mistake. if I ever end up with another stick truck I will for sure get a south bend. ive heard it stated that the valair can hold 600hp as a single disk clutch I find that hard to believe. I had one of the baddest LUK cluthes I could find and it held 6 months max with about 500hp
well its not looking good from reading the website
Warranty Information
ValAir Inc. warrants that our Performance Series Clutches are free from defects in workmanship and material under normal use and service for a period not exceeding 12 months or 12,000 miles whichever occurs first from the original date of purchase.
The Limited Warranty will not be valid under the following conditions:
Flywheel was not replaced or resurfaced to specification before new clutch installation.
Clutches which have been physically altered, incorrectly installed, damaged by accident, negligence or misuse.
Burned or Scorched Clutches.
Clutches used for high performance events or applications (Drag Racing, Sled Pulling etc.) which were not specifically designed for these high performance events whether performed by an licensed organization or solely by the individual.
The obligation of ValAir Inc. under this warranty is limited to repair or replacement of the defective product/s. Inspection shall disclose to the satisfaction of ValAir Inc. that the clutch and/or components are defective.
Buyer must return the defective parts only once he/she has received the consent or authorization of the seller. ValAir Inc. shall not be liable for any special, direct, indirect, incidental or consequential damages, including, but not limited to, loss of life, bodily injury, claims for delay, loss of profits, or for labor.
No express or implied warranties either of merchantability or fitness for any particular use or purpose or otherwise, other than that expressly set forth above which are made expressly in lieu of all other warranties, shall apply to clutch products sold by Valair Inc.
I'll bet that your rear main is leaking a little oil. No way that clutch will not hold what you have. Must have an oily flywheel or you some how damaged it back when it was first installed with the disengagement problem. I'd still call Dan, he gave me a free upgrade when my organic 13" started to slip 2 months after install. The FE is wicked, I have it. But if by chance it is toast, all you got to do ask, he is still trying to build his reputation so at the very least, he'll cut you a deal on a double disk.
[quote=03dodgeoffroad1;1992043]well its not looking good from reading the website
****Clutches used for high performance events or applications (Drag Racing, Sled Pulling etc.) which were not specifically designed for these high performance events whether performed by an licensed organization or solely by the individual.
WHAT ARE THEY MAKING THEM FOR??????Mini Vans?????
South Bend all the way!
WHAT ARE THEY MAKING THEM FOR??????Mini Vans?????South Bend all the way!
I'm pretty sure what they are saying is you can't be trying to sled-pull with a single disk clutch and expect it to last. I own a Iron Giant Southbend clutch, the first one failed because of some bad material and they sent me a brand new one they have been good to me. But if Valair can build the same clutch for half the price I know where my next one will come from. Competition is a good thing.
