updating new x2???
Old Nov 15, 2007 | 11:08 AM
duallydave's Avatar
updating new x2???
hi i just got my new x2 and i want to install the mm tune into it.i downloaded the right tune and installed the program but it keeps saying cant find module,can i uninstall and try again?i did a search on here but it keps saying x2 was to small of a word to search,huhhhhh,anyone else have this problem.thanx
Old Nov 15, 2007 | 02:36 PM
welndmn's Avatar
Do you happen to know if you have installed the .net Framework from Microsoft?
Old Nov 15, 2007 | 02:53 PM
06megacabman's Avatar
Need a little more info. Are you running XP or Vista or ??
I have the X2 and when running Win XP you should run the MM file first which brings up the programming window. Plug the module in next. If you look inside the module from the 20 pin connecter end you will see a little red light on inside. At that point I usually click on "Get information from Module". If it reads correctly and shows the Feature Code(s) I then click on "Update Module". Make sure if you are running XP you have Microsoft .net loaded.
Old Nov 15, 2007 | 03:03 PM
duallydave's Avatar
sorry,i am running xp,i do have the red lite on the module,i start the program first then conect my module and is says getting info from module and thats about it.i keep clicking rety but nothing esle hapens,im sure i have net thingy but where would i look to make sure?thanx for the replies
Old Nov 15, 2007 | 03:23 PM
duallydave's Avatar
i found out i have netframework 1.1 installed.it just wont see the module,in device manager i can see the module and it says it has a driver installed and its working properly.im confused????????
Old Nov 15, 2007 | 04:52 PM
At this point I'm not sure. Seems like Quads SW has been a little finicky sometimes. Might try calling Quad customer service at this point. Sorry.
Old Nov 15, 2007 | 06:59 PM
donhov's Avatar
Mine acted like youa re describing, I removed it from the program manager and then ran the software again and waited for it to tell me to plug in the module, at that point it took a few minutes and all sudedenly was good. Try removing the software and re-installing it again. Worked for me.
Old Nov 15, 2007 | 09:20 PM
duallydave's Avatar
i tried uninstalling the program but it doesnt show up on my program list,i deleted the application but that doesst do anything,does an uninstaller come with the program?ive been fightinh with this thing all day,almost thru the puter out the window,ill give quads guys a call tomorow.any more tips??
Old Nov 15, 2007 | 10:47 PM
woodrep's Avatar
This happend to me as well. I talked to Roark at Quadzilla about it. When you pull up the screen to "get info from module" there is the Quadzilla logo on there. I did not click on that first. By clicking on the logo, it takes you through the step by step on recognizing the driver for the X2. Try that out next and see what happens (famous last words ha ha). This might get you over the hump on this one. Hope this helps.
Wood
BRUISER
Feb 20, 2008 12:15 PM
AggieJustin
Jan 29, 2006 08:42 AM
manganos
Jan 8, 2006 05:26 PM
DeanM
Apr 11, 2005 09:47 AM
USMC64-70
Sep 7, 2004 03:17 PM
