Update # 2
#32
Guys I figured out my stutter problem, one of the wires on the TST harness that ties into the rail pressure was loose in one of the connectors and was causing the problem!
I feel alot better now.....!!!!!!
Truck is running fine, loaded TNT-R SW#7, TM-2, Timing-2, RP-3, wastgate off and seen about 44psi with the Smarty!
Ill get some more time this weekend to play around with the settings...
#36
#40
well buddy, god to meet ya down there at Lloyd's place, see ya at spring fling , if ya just would have asked I would have let ya borrow the fooler for a test run. get that wire fixed yet ?
#41
Not yet Mike, man Ive been busy since I found the problem.
Cant wait for Spring Fling DUDE, it was good to meet you to man!
Mike my TST is doing boost fooling beyond what the Smarty dose, so I dont really think the fooler wold have made a difference.... IDK
#42
Preston I took Lloyd for a ride and he said the noise is normal!!
#43
I hit 50 psi out of my poor 64 Buddy. But that is probably because I have 150HP stixs and it gets pretty hot from 55-110. But then again from 55-110 is just a matter of a few seconds now. Injectors woke this truck up so bad, it is just ridiculous. This truck is stupid fast and I haven't even got half way done with my build up. I am going to try a boost fooler since I heard the Smarty only boost fools to 45 psi.
#44
Joey Im starting to think I just need some injectors, but Chris said I shouldnt have any problem getting boost out of it with what I have now....(stock sticks, stock cp3)
#45
Yeah Buddy, I heard the same thing from Chris. I have 150HP stixs and a stock CP3 for a bit. And I don't know why I can't get over 50 PSI. Maybe it is because the stock CP3. But the Edge EZ should boost fool some what. I should be nailing at least 60 if I wanted, but I have the waste gate all the way in and still doesn't go above 50 psi.
