Twins+Exhaust brake
Old Feb 21, 2006 | 11:52 PM
BlueDually's Avatar
Twins+Exhaust brake
Ive been looking at all the posts on twins, and like the idea of the Arctic Air set, where I dont have a perfectly good turbo sitting on the shelf and the lower cost.........
but is there anyway my bd exhaust brake could be kept on the backside of the stock, top turbo. Then add another 45 piece down toward the big turbo. Or would that place the second turbo to far back, rubbing the firewall,
My espar is bolted horizontally above the exh manifold, right were the primary turbo would end up, but I think that could be moved where the air box use to be
Also are those turbos just supported by the manifold, or some other brackets, looks like alot of weight
Old Feb 22, 2006 | 09:40 AM
Jeff K's Avatar
It has been done. There is a guy on TDR that did it. His name is robertyoke and if you are a member there you can search his name and see his thread with all the pictures.
Old Feb 22, 2006 | 12:32 PM
BlueDually's Avatar
You wouldnt have any pics would you, Im not a tdr member,
Old Feb 22, 2006 | 12:47 PM
Jeff K's Avatar
Here are the pics... http://community.webshots.com/album/273256516NxRijF
Here is the thread... http://www.turbodieselregister.com/f...d.php?t=123316
Old Feb 22, 2006 | 01:41 PM
BlueDually's Avatar
Hey, thanks for the links, great pics, bump the tdr link says I cant see the thread because Im not a member , bla, bla,
Do you think you could bump the thread if your a tdr member, so I could run through it. Thanks
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
signature600
Mar 2, 2005 06:50 PM
