Turbo differences??
Old Jan 19, 2008 | 03:08 PM
HotRodK's Avatar
Question Turbo differences??
Are there any dfferences between an '04 turbo and one off an '04.5+? Thanks!
Old Jan 19, 2008 | 03:48 PM
PourinDiesel's Avatar
Yeah there is.
Old Jan 19, 2008 | 03:50 PM
HotRodK's Avatar
Wink
Ummm, could you be a little more specific?
Would if be good to swap one to an '04?
Old Jan 19, 2008 | 04:45 PM
bluechrome's Avatar
I would make only a very slight difference. not worth a swap.one has a mechanical wastegate and the 04.5 is electronic
Old Jan 19, 2008 | 04:47 PM
HotRodK's Avatar
Question
Then my ECU probably wouldnt control that turbo anyways?
Old Jan 19, 2008 | 04:50 PM
No it won't but you can just by pass the controlled wastegate portion and run a direct pressure line to the wastegate diaphragm and it will work just fine.
Old Jan 19, 2008 | 07:08 PM
HotRodK's Avatar
So it probably isnt worth the swap, it doesnt sound like.
Old Jan 19, 2008 | 07:54 PM
cgmorgan06's Avatar
I thought about installing a turbo from 04.5 or newer on my 03. After quite a bit of reading, I could not justify spending that money on a "stock" turbo. So I decided to go with the htt 64/13 and no regrets at all about it.
Old Jan 20, 2008 | 11:28 AM
HotRodK's Avatar
But what if it only cost you labor, and the turbo was free?
Old Jan 21, 2008 | 11:57 AM
XLR8R's Avatar
Didn't the '04 and earlier HPCRs come with an HE341? ('04.5+ 5.9L have HE351s)... same exhaust side, but smaller compressor than the 351, IIRC.
Old Jan 21, 2008 | 11:59 AM
soulezoo's Avatar
DTR 1st Sergeant
YUP!........
Old Jan 21, 2008 | 02:24 PM
rrod612's Avatar
i think the 04.5 have a little bigger downpipe
Old Jan 21, 2008 | 02:29 PM
rip 112's Avatar
Yeah they do, but that can be changed real quick.
Old Jan 21, 2008 | 02:39 PM
rrod612's Avatar
can i put a bigger downpipe on my 03 or do u have to change the turbo? if so where can u get one
Old Jan 21, 2008 | 02:46 PM
rip 112's Avatar
You can change out your downpipe to a 4". I got mine through MBRP with my stacks, but you should be able to find one from any of the members on here with aftermarket exhausts on 04.5 up.
