tst update
Old Dec 22, 2006 | 05:26 AM
chw's Avatar
chw
tst update
can i send in my early twins tst and get the adj. timing program put on it?? how much does this cost?>
Old Dec 22, 2006 | 06:26 AM
wap's Avatar
wap
what remote do you have?
If it is the R49 I think you can do it other than that I dont know, just give em a call to day and ask em. It may be useful to have your serial number on hand when you call.
Old Dec 22, 2006 | 07:28 AM
OT-OF-Here's Avatar
TST update
It all has to do with your serial number,... that's the key. Call TST and ask for Danny and he can tell you. Yes, it needs to be the R-49. $50 will get it done. You also get the turbo cool down feature which is sweet.
Old Dec 22, 2006 | 07:40 AM
COUNTRYBOY's Avatar
Look on your TST box and if it has a serial number higher than 5000 you can have EVERYTHING! TT03, TT05, Standard, rail pressure (like a MP8), rail pressure gauge, adjustable timing, cool down timer by temp or time. You just need the controller. Stack it with a SMARTY and hold ON!
Old Dec 22, 2006 | 08:44 AM
chw's Avatar
chw
what do you mean box? like the box it comes in or the box itself that you mount on the truck??
Old Dec 22, 2006 | 10:36 AM
RamWheelsBy4's Avatar
The serial number they refer to should be on the module mounted under the hood.
Old Dec 22, 2006 | 11:43 AM
maddog madden's Avatar
Yes you can, I had a 1400 serial number(an early one) And it has everything except the fuel rail pressure and adjustment. Other then that it has adjustable timing, early and late twins along with standard and economy programming, turbo cool down timer, everything that the new ones have. I know have the r49 since I wanted the fuel rail pressure option. It cost me lie $250 and that included a new wiring harness which u will need if you want the cool down timer. Other then that it worked as good as my new one.
Stealth Mode
Dec 19, 2006 05:07 PM
king d
Jan 19, 2006 07:22 PM
MnTom
Aug 25, 2004 11:19 PM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
