TST R49 or Smarty and gauges ?????
Old Jan 31, 2007 | 01:34 PM
tauberson's Avatar
Title says it all.....
Old Jan 31, 2007 | 01:36 PM
BigBlue's Avatar
Smarty and gauges. It's just so cool to see gauge pods and the smarty is much more user friendly. Not to mention I like analog gauges because they seem to give quicker readings that don't bounce around a lot and to me that makes them more accurate.
Old Jan 31, 2007 | 02:10 PM
D.Wiggs's Avatar
BOTH!!! THat's what I run! But I would DEFINITELY and UNEQUIVOCALLY start with the Smarty & Gauges if that's all you can afford, an dthen add the TST later. I am loving my truck right now and I only run the TST on 1/0 for now!
Old Jan 31, 2007 | 02:21 PM
qzilla's Avatar
I am the first to say that I think analog gauges are fine and I do like the looks of them.
BUT
Because they do not move around as much does not make them more accurate. The best analog gauge you can buy will do EGT measurement in 25 degree increments. Digital Gauges (ours for example) will measure egt in 1 degree increments. So naturally it is going to move around more.
Also the analog gauges have a mechanical limitation as to how fast it can actually sweep. On a digital gauge you do not have this loss of time due to mechanical limitations. We can show the data in 100% real time.
I promise you that analog gauges are not as fast and they certainly are not precision instruments. They work fine and there is nothing wrong with them but, I wanted to clarify some musunderstandings.
Old Jan 31, 2007 | 02:36 PM
D.Wiggs's Avatar
BUT
That's why I think both are best. I use the analog as my reference, but can use the TST if I want exact, real-time data.
Old Jan 31, 2007 | 02:46 PM
Mark1si's Avatar
I have both. TST R49 a mechanical boost and rail gauge.
Old Jan 31, 2007 | 03:05 PM
rstone's Avatar
I would go with the smarty it much easier to use. I had the new tst it was to picky you could barely turn it up before it started to cut out and throw codes.
Old Jan 31, 2007 | 03:21 PM
JohnInNH's Avatar
My vote is: Smarty and Gauges
Smarty can read and clear codes. Different SW for different applications. Gauges a must anyway. (mine are going in this weekend)
Old Jan 31, 2007 | 05:48 PM
MOJO1's Avatar
BDDL and GAUGES I Mean SMARTY forget the TST!
blackbanshee
18
Feb 4, 2010 12:17 PM
Highmark
16
Jul 11, 2007 10:26 AM
subspd
Aug 9, 2006 08:37 PM
Mopar72
May 23, 2006 10:57 AM
03CumminZ4X4
Jan 23, 2006 01:49 PM
