tst installed
Old Mar 19, 2005 | 05:27 AM
king d's Avatar
tst installed
just installed my power max yesterday,very nice instrucions and a seemingly well built unit.however i must admit i thought something was wrong at first .but i guess the tst just doesnt have the bottom end of the crazy larry,of course i didnt run the tst all the way upeither to much smoke .hopefully with some more air i be able to try the upper levels of the power max. the dyno will tell the tail though but i feel like the crazy larry is putting more useable power out as of now......jess
Old Mar 19, 2005 | 07:57 AM
502502's Avatar
Keep in mind that the regualr program (not the twins program) was made to not smoke until the very high levels --
So the tru kwill not fuel until boost is somewhat there
And also, the crazy larry program does have fuel pressure raised... So you should stack an EZ with it (the tst), and see what you think, that will be close to the Bullydog's crazy larry
Heck with tst/ez I gained 236 hp on the dyno -- not tot shabby
Old Mar 19, 2005 | 04:20 PM
king d's Avatar
well i installed the va pressure box and it picked up the tst a great deal,i am going to run it like this for a while and see what happens
Old Mar 19, 2005 | 05:50 PM
PourinDiesel's Avatar
I tried an older TST Cr program on my truck for about 5 miles.
Talk about fueling hard!!
I run the regular non-twins program.
Truck runs very smooth, but the power is there when you want it!
GOOD BOX!!
Old Mar 19, 2005 | 10:57 PM
RadRam's Avatar
I have & run the old tst program - aggressive yes.
But the pup stacked has very good smooth btm end power.
Put it this way tst 5x5 + a predator or a quadzilla never slipped my con fe.
The pup on 130 hp + the predator slipped my con fe - so im thinking that combo must have a good lowend. Smokes way more than the tst also.
PourinDiesel is right tho - the tst is a great box.
mjpalmer
May 19, 2005 11:34 AM
WhiteSport600
Dec 23, 2004 09:59 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
