Truck threw out some codes
Old May 14, 2007 | 04:32 PM
jgarrett's Avatar
So i get in my truck this afternoon after a 200mile road trip last night and the engine light is on and there was no smoke or power. I pulled over and put my smarty on it and have 3 codes (2 new).
Old...........checksum error
NEW..........p0299 - boost in range low
..........p0234 - turbocharger overboost
my smarty was on 7 and i put it back to stock and the codes cleared
what is goin on with this thing
Old May 14, 2007 | 06:13 PM
Bob Wagner's Avatar
the P0299 is caused by your turbo. The P0299 will throw you into limp mode too. call your rurbo supplier for a fix
Old May 14, 2007 | 06:32 PM
jgarrett's Avatar
the code is gone since i returned to stock software........is the problem gone
Old May 14, 2007 | 06:34 PM
Bob Wagner's Avatar
the codes are cleared when you return to stock. If the truck see's the underboost condition again the code will be set and the truck will go into limp mode.
smarty is not causing the code
Old May 14, 2007 | 06:36 PM
jgarrett's Avatar
i didn't think it was...........what is the turbo tryin to say
Old May 14, 2007 | 06:46 PM
53 willys's Avatar
quit lugging me
Old May 14, 2007 | 06:47 PM
jgarrett's Avatar
is it ok???
Old May 14, 2007 | 06:54 PM
53 willys's Avatar
stock turbo??
Old May 14, 2007 | 07:01 PM
53 willys's Avatar
I cant find any info on p0299???
P0234-TURBOCHARGER OVERBOOST CONDITION
WHEN MONITORED
While running.
SET CONDITION
The intake air pressure is above a calibrated value for a calibrated amount of time.
POSSIBLE CAUSES
  • Other DTC's
  • Wastegate stuck
  • Turbocharger and/or wastegate damage
  • Wastegate
  • Turbocharger
  • Wastegate control valve
P0299-BOOST IN RANGE LOW
WHEN MONITORED
While engine is running.
SET CONDITION
The boost pressure is lower than the expected boost pressure based on engine operating conditions.
POSSIBLE CAUSES
  • Other DTC's
  • Intake air system restriction
  • Turbo charger damaged
  • Intake air system leak
  • Boost pressure sensor
  • Turbocharger
  • Intermittent condition
Did "checksum error" have a P code with it or is that all it said???
Old May 14, 2007 | 07:04 PM
jgarrett's Avatar
i think it was p0602
Old May 14, 2007 | 07:05 PM
jgarrett's Avatar
and yes stock turbo
Old May 14, 2007 | 07:13 PM
53 willys's Avatar
P0602-CHECKSUM ERROR
WHEN MONITORED
While the ignition is on.
SET CONDITION
A deviation between the ECM memory and a stored calibration.
POSSIBLE CAUSES
  • Flash ECM
  • ECM
Old May 14, 2007 | 07:15 PM
53 willys's Avatar
maybe it is Smarty causing codes?????
https://www.dieseltruckresource.com/...ighlight=p0602
jgarrett's Avatar
i think the smarty may have caused this one
Old May 14, 2007 | 07:19 PM
jgarrett's Avatar
is my turbo ok now that the codes are cleared and have not came back yet
