trans temp install
trans temp install
got my isspro gauge today, the gauge install is self-explanatory but how on earth does the sender mount in my PML pan? i have 3 brass and plastic fittings and no instructions on installing them
IMO - it's kinda cheap of PML not to provide a pre-tapped hole with a pipe plug.
Originally Posted by Tom488
Looking at the picture on PML's website, it looks like there's a boss next to the drain plug that can be drilled/tapped. Drain the fluid (use a clean catch can - you can re-use it), then drop the pan, and drill a hole through the center of the boss. Use either a 23/64", 11/32", or 5/16" drill bit (listed in order of preference - the 23/64" is the closest to the recommended hole size for 1/8" NPT threads), then tap the hole with an 1/8"-27 NPT pipe tap. The sensor will thread into the hole. Replace the pan, re-fill the fluid, make sure the newly tapped hole doesn't leak (tighten it more if it does), and hook up your wiring.
the black plastic spacers on the fittings confused me
i don't know what they included them for. i threaded the 3/8" fitting into the boss, worked great.
Richpwb
Aug 15, 2008 08:01 PM
wexman
Feb 17, 2004 05:57 PM
live wire
Jul 21, 2003 07:26 AM
