tranny shifting funny with triple dog low end power?
can anyone CONFIRM that the wierd tranny shifting we are all having with the low power on is ACTUALLY harming the tranny? i am going to adjust my bands tomorrow and see how it does...BTW does anyone have the steps to adjust the rear/low band on the 48re's? thanks
48re band adjustment
From Service manual on Band adjustment.
FRONT BAND
The front (kickdown) band adjusting screw (2) is
located on the left side of the transmission case above
the manual valve and throttle valve levers.
1. Raise vehicle.
2. Loosen band adjusting screw locknut. Then back
locknut (1) off 3-5 turns. Be sure adjusting screw
turns freely in case. Apply lubricant to screw
threads if necessary.
3. Tighten band adjusting screw to 8 N·m (72 in. lbs.)
torque with an appropriate Torx™ socket.
CAUTION: If Adapter C-3705 is needed to reach
the adjusting screw, tighten the screw to only 5
N·m (47-50 in. lbs.) torque.
4. Back off front band adjusting screw 1-3/4 turns, for
diesel vehicles, or 1-1/2 turns, for V-10 vehicles.
5. Hold adjuster screw in position and tighten locknut to 41 N·m (30 ft. lbs.) torque.
6. Lower vehicle.
REAR BAND
The transmission oil pan must be removed for access
to the rear band adjusting screw (1).
1. Raise vehicle.
2. Remove transmission oil pan and drain fluid.
3. Loosen band adjusting screw locknut 5-6 turns. Be
sure adjusting screw turns freely in lever.
4. Tighten adjusting screw to 8 N·m (72 in. lbs.)
torque.
5. Back off adjusting screw 3 turns.
6. Hold adjusting screw in place and tighten locknut to
34 N·m (25 ft. lbs.) torque.
7. Position new gasket on oil pan and install pan on
transmission. Tighten pan bolts to 17 N·m (13 ft.
lbs.) torque.
8. Lower vehicle and refill transmission with MoparT ATF +4, Automatic Transmission fluid.
I got the manual for my truck free at hemitruckclub.com on the left side of the main page....(yes it contains everything for diesels also) Gotta love the internet!
FRONT BAND
1. Raise vehicle.
6. Lower vehicle.
REAR BAND
1. Raise vehicle.
torque.
lbs.) torque.
quicksilvr
Apr 2, 2009 02:38 PM
CTD2001
30
Feb 16, 2009 03:34 PM
Brendan
Oct 17, 2007 11:12 AM
zander79
May 8, 2007 12:25 PM
Hammer Down
Sep 4, 2006 01:05 PM
