trac bar install-alignment???
Old Jun 13, 2007 | 06:33 PM
rjm022's Avatar
my don thuren trac bar should be arriving this week.. i had my truck aligned about three weeks back when i replaced the entire front end. i do not have a lift,so will i need another front end alignment after the trac bar install???
Old Jun 13, 2007 | 06:35 PM
ptgarcia's Avatar
If you install it set to the same length as the stocker there's no need for an alignment.
Old Jun 13, 2007 | 07:00 PM
Fisherguy's Avatar
Why are you changing the trac bar if it's not lifted?
Old Jun 13, 2007 | 07:04 PM
ptgarcia's Avatar
The factory parts wear out quickly and are a big contributor to poor steering. Don's bar is vastly superior.
Old Jun 13, 2007 | 07:14 PM
rjm022's Avatar
fisherguy- i just replaced the entire front end, including installing the dyna-trac free spinning hubs- the only the left to replace is the trac bar and to install the dss steering stabilizer. thanks guys.
Old Jun 13, 2007 | 09:41 PM
Fisherguy's Avatar
Okay, just curios..
Old Jun 13, 2007 | 09:44 PM
Raspy's Avatar
The track bar should not have any affect on the wheel alignment but it might affect the steering wheel position. I'd like to know if the truck steers better with the new bar.
John
Old Jun 13, 2007 | 10:27 PM
Dan Marino's Avatar
Don Thuren stated to me that its a good idea to use a trac bar even with a wheel and tire upgrade. I went to a 33X12.50 tire and a 10 inch wheel. He states that the trac bar will help with handling becasue of the wheel and tire width.
89dieselkong
Feb 12, 2011 10:06 PM
silkywoods
Nov 10, 2007 03:52 PM
rjm022
Jun 30, 2007 02:54 PM
CODODGE2500MAN
May 24, 2007 01:00 PM
Fishbait
Dec 5, 2005 09:17 AM
