Towing Turbo?
Old Feb 3, 2008 | 02:33 PM
bigwheels94's Avatar
Towing Turbo?
I haul a slide in camper, & soon will be getting a jeep to tow behind. I'll gross @ 14K. With the mods I have, running My Jr. @ 100, & my XZT on the stacking program. What turbo?
Old Feb 3, 2008 | 03:00 PM
C Schomer's Avatar
My ATS A2k is great! ATS made the new A3k respond like the old A2k and they dropped the A2k. Neither one needs a wastegate cuz they have such big turbine housings so egt and drive pressure is low and nothing is wasted. Craig
Old Feb 3, 2008 | 03:01 PM
Megaramasaur's Avatar
No question, the best towing turbo is the Silver 62. Spools incredibly fast and keeps the EGTS in check even with Smarty beta 4.4 on 9 and towing.
Old Feb 3, 2008 | 03:33 PM
Thanks for the input. I just wonder if I have the fuel to spool it as fast as others. I'm only running @ 425hp. & don't plan on going any higher.
Old Feb 3, 2008 | 06:09 PM
Jetpilot's Avatar
You probably will like a 62/71 turbo, either HTT or II both are nices pieces. The Silver 62 is overkill for all except those wanting to try and wring a little more out of a 62mm turbo without jumping up to a 64. The larger exhaust turbine of the silver 62 means less turbo boost/cooling at cruising speeds.
Old Feb 3, 2008 | 09:15 PM
Thanks. I think I'm going to get the HTT 62/71/14 SS. I hope it spools fast enough with my Goerend.
edonald849
Feb 22, 2009 04:44 PM
Ada381
Feb 10, 2008 07:58 AM
cincydiesel
Jun 23, 2007 08:39 PM
Trusty Steed
Feb 24, 2004 07:11 AM
Tob
Feb 19, 2003 03:53 PM
