towing with smarty
I think it depends on what smarty program you are running. I don't tow anything with the smarty except during a sled pull. The egts get to hot for towing even on 3.
If you have the smarty on watch your pyro!!!
Same with me. I tow 16k in the mountains with the Smarty on 3. The only thing you have to do is be help it downshift so it RPM doesn't drop under heavy load. I wish that when it was in tow/haul it would downshift earlier. I have benn caught with high EGTs a few times but it is always when I least expected it, like a slow switch back road and the truck stays in third instead of downshiftling like it would if I was on the throttle hard. All in all the Smarty on 3 is lower EGTs than stock.
I tow +10k in mountains on SW#5 with no issues.
Same here! But you definately have to watch your gauges. But mine seems to run cooler than stock under normal conditions unless I put my foot in it.
I just did 5300 miles towing 8,000 TT most of it in the mountains. Smarty on mild #3 - sooted up the trailer at high attitudes, under load. What a mess. Changed the software to after-market injectors/stock turbo/mild/SW#3 and eliminated the soot problem. But with either setting I had to watch the EGT. It would get hot fast!! Like stated before, a pyro is needed and watch your rig to see how it reacts to the Smarty.
#9 all day long... Towing 12-14k
but of course monitoring engine paramaters is a must!!
