Towing with built tranny?
Old Mar 18, 2008 | 08:11 AM
abc4yew's Avatar
I have both an 03 and 04 but your problem probably the ecm as mine shifts like butta on the 3/4 shift but it is very throttle sensitive...If you keep over 75% TPS then it won't shift until 3k and then the shift drops it right to the sweet spot of tq and hp and off like a jet. If you soft pedal it will shift at 2500 and that is the minimum you want towing. A 2300rpm shift is grannie stuff. KS
Old Mar 18, 2008 | 08:13 AM
HOV's Avatar
HOV
Originally Posted by Megaramasaur
Can someone tell me how many RPM's you drop when your converter locks... mine's about 700, so if I'm at 53 when the converter locks and say 2300 rpm, it drops to around 15/1600, and seems to lug for a second or two.... could it be my gear ratio is whacked... maybe I should be running 4.10's?
700 RPM drop is not a TC lock, that's a shift.
If you're at 2300 RPM around 50 MPH, you're definitely in 3rd gear.
Old Mar 18, 2008 | 08:24 AM
cincydiesel's Avatar
My T/C locks up almost instantly after the 3-4 shift. Sometimes I can run higher in the rpms before it locks and sometimes it locks right at 50 mph. The 50 mph lock up is harsh.
Old Mar 18, 2008 | 08:27 AM
abc4yew's Avatar
I thought it was obvious that we were talking about a 3/4 shift and lock up but yes his original comment is off a bit.ks
Old Mar 18, 2008 | 04:22 PM
Megaramasaur's Avatar
This is definately not the 3-4 shift, it's right after that... it's at lockup
Old Mar 18, 2008 | 06:32 PM
Big P's Avatar
Like you said, it must be an 05' thing, because mine is exactly the same.
Old Mar 18, 2008 | 06:43 PM
BigB82789's Avatar
You must have an awefully sloppy converter. I know mines a 47re, but mine drops maybe 200 rpms.
Old Mar 18, 2008 | 06:44 PM
Floor It's Avatar
Dan is not talking about the shift into 4th "harshness" or shift and lock-up timing. He is talking about the the loosness of the TQ, Dan that does seem to be abit too much RPM drop on lock up to me, have you talked to dave yet? Dan the new experimental FCA testing is alomst done and will be sending one your way to test real soon.
John
Old Mar 18, 2008 | 10:44 PM
abc4yew's Avatar
If you are revving 2300 in 4th to get 53mph I'd trade that tranny in on a shopping cart. If you drop 700 rpm at 2300 rpm that is one sloppy loose TC. That would be 66% efficient....are you still using the stock TC...It sounds like it. What is the stall on that converter....4500rpm ...You don't need a hopped up CP3... you need a good tranny as that is just crazy. KS
Old Mar 19, 2008 | 05:42 AM
jrussell's Avatar
Sounds to me like it's shifting from 3-4 then immediately locking up the TC at the same time. A shift plus TC lockup will drop it that many RPM's. I doubt there's anything seriously wrong with your tranny/TC.
Old Mar 19, 2008 | 07:14 AM
I'm going to call Dave today...
Thanks for the update John, I'm looking forward to it..
Well I better go... it will take me a long time to get to work this morning in my "shopping cart".....
Old Mar 19, 2008 | 07:58 AM
We youre pullin 22,000 on the G/N and your T/C locks at the same time as the 3-4 shift at 50 mph ITS ONE HECK OF A SHIFT and hell on the turbo. I've called Dave with this concern twice now and he tells me the same thing. "We can either turn down the line pressure or wait till DC comes out with a TSB for this. Turning down the line pressure will NOT provide enough pressure to keep the T/C locked" He also tells me that the newer 04.5 and the early 05's are notorius for this. The RPM will only drop around 500-600 during the shift
abc4yew
28
Oct 30, 2024 04:25 PM
jesussaves
Dec 30, 2009 06:35 PM
JKM
Oct 12, 2005 07:58 AM
stevenknapp
27
Jul 10, 2004 01:11 AM
