Top rail liners
Old Apr 28, 2004 | 01:04 AM
mlankton's Avatar
Top rail liners
I am sold on Line-X spray in liners after seeing a couple on trucks at work. My question is, do you recommend having them spray the top rails too, or is the hard plastic top rail liner better, and why?
Thanks
Old Apr 28, 2004 | 03:33 AM
MedicShawn's Avatar
I had them do the bed with over the rails and also spray my rocker panels.
Old Apr 28, 2004 | 10:33 PM
Truckjerk's Avatar
Shawn, got any pics of the rockers with coating? I have pretty much the identical truck to yours, and wanted to see what this looked like before i had it done.
Old Apr 28, 2004 | 11:31 PM
MedicShawn's Avatar
There are pictures in my gallery. There are three before I had them done and three after.
Old May 1, 2004 | 12:08 PM
chrismez's Avatar
Get the over the rail liner. Only a few bucks more and well worth it......
Old May 2, 2004 | 10:03 PM
moopa's Avatar
With Line x over the rail, will it seal ok with a truck topper?
Old May 3, 2004 | 07:00 AM
natstayl's Avatar
Re: Top rail liners
Thanks
You don't say if your truck is 4x4 or 4x2? Do you plan to use a topper? If it's 4x4 its already plenty high off the ground and plenty hard to climb into and out of the bed. I went with over the rail, and would gladly do so again, because I haul 10' lengths of PVC pipe and lumber etc. as well as small parts that I drag over the rail instead of out the back, but that's just me. Nat
5.9Excursion
Mar 13, 2008 10:56 AM
CTD NUT
Off Road / 4x4
Oct 20, 2007 01:57 PM
96_12V
Sep 8, 2005 08:57 AM
