Tnt
Tnt
I know this has been beat to death but what settings should I use on the tnt to get the most hp out of it?? I was thinking of loading it up tonight and see how it acts. My mods are in my sig.. Thanks!
no problem like soulzoo said sw7 first .every truck is different, but personally sw9 is where its at. t/q 4, timing2 since you have sticks, r/p try3 first, then4. thats where your biggest numbers will come from. IMO. GOOD LUCK
all right I will try that thanks for the tip!!
well got it in the truck and did some test drives. first on sw 7 no poping and held 24,000 rail preasure, and smoked more than 4.2 beta. Then sw 9 poping and held 22,850 rail preasure, smoked heavy to 2,600 rpm then dark haze till time to shift. Smoke dose not bother me, but would more timeing be beter for more hp or leave it? I am at timeing #2. can't tell if it is more power than 4.2 beta or not. but it dose hall a**. beta 4.2 dose not smoke near as much as TNT. 4.2 is more reasponceive down low.
Drove the new tnt tune to work and I was wandering if it fuels that much more would to much fuel hurt turbo spool off the line? if I chaned pump timing from #2 to a different # to stock or to hugh. would that make a dif on spooling?
