Tire wheel combo question
Hey all,
If I run the 325/65R18 Terra Grappler on a procomp series 7089 18x9 wheel whith 4.75" backspacing with -6mm offset, without any mods to the suspension will it rub. My guess is the wheel will stick out of the wheel well too far.
Might have to go to the 295/70R17 b/c it'll fit better on the rim.
thanks Jamie
thanks Jamie
Hey all,
thanks Jamie
thanks Jamie
I am sure a 2" level kit would clear ok.
Or you could run a 325/60/18 instead of 325/65/18, I don't believe that size rubs because they are not quite as tall of a tire. bthanks runs 325/60/18s on his truck with a leveling kit and they don't rub. I have heard before that the leveling kit doesn't help with the rubbing issue because they rub the control arms instead of the fenders.
edit just looked at the specs my wheel is 18x9 the 325/60/18 calls for at leat a 9.5 and I don't want to have my centers worn out.
thanks Jamie
rock crawler
17
Jan 25, 2007 10:52 AM
Jmac
Feb 25, 2005 01:16 PM
hooked3800
28
Aug 26, 2004 01:13 PM
cummer01
May 26, 2004 02:20 PM
