exhaust brake
Old Jan 29, 2007 | 09:55 PM
06dodgedrw's Avatar
exhaust brake
i have been reading on here to see what brake is better the pac or the jake and its hard to really figure it out what is favored. i have an 06 with a 6spd. and am very interested, the truck has 10k on it and i tow an excavator and trailler that is about 16,000lbs combined. i was woundering if some 1 could give me the pro's and cons of the 2 and the differences on how they work. and if possible i would like to keep the truck under warrenty. thanks alot
Old Jan 29, 2007 | 09:57 PM
HANER400's Avatar
have you looked into the u.s.gear brake.i have a 4 inch inline on my 99 and really like it
Old Jan 29, 2007 | 10:39 PM
ptgarcia's Avatar
HANER400,
I'm trying to get feedback on the US Gear D-Celerator from someone who has used it. How long have you had yours? Have you had any problems/issues with it? Thanks for any information you can share!
Old Jan 29, 2007 | 10:41 PM
JuzPlaneKrazy's Avatar
Exhaust Brake
Jacobs is the only one that will keep your warranty that I know of. Go to the Dodge Truck web site and you'll see the one they want us to run.
Old Jan 29, 2007 | 10:45 PM
HANER400's Avatar
ptgarcia,
i have had the brake for bout a year.no problem or any issues so far.i am very pleased with mine,works great.
Old Jan 30, 2007 | 12:01 AM
danc46's Avatar
The PacBrake is much cheaper than the Jacobs brake by about $450 to $500.
On the 06 an addition of the PacBrake will not void your warranty as your ECM is programmed to lock up the torque converter when equipped with an exhaust brake. If I add one, it will be the PacBrake. $750 for the PacBrake vs $1100 from Cummins (even more from a Dodge Dealer!) being the deciding factor.
Old Jan 30, 2007 | 12:17 AM
morkable's Avatar
the pac brake wont affect your warranty, and it is said to be a better unit than the jake,, I am going to go with the pac brake personally after doing alot of research on it
Kevin
Old Jan 30, 2007 | 12:34 AM
rich's Avatar
i run the jake on both trucks i like it a llot and havent had a bit of problems got 30k on th one in the 07. it bolts right in only takes about 4 hrs to install
Old Jan 30, 2007 | 07:13 AM
SkyHarborCowboy's Avatar
I didnt know that 6 speeds had a torque converter! I have the Jake and I love it. I bought mine on ebay new from a dealer back east for $700. Couldnt be happier!
Joe
Old Jan 30, 2007 | 08:43 AM
mattk50's Avatar
I have the us gear as well and and have been very happy with it.I've had it for about 2 years now and it has worked flawlessly.
Old Jan 30, 2007 | 10:57 AM
heredia_mike's Avatar
who is most competive with PAC Brake pricing? i seen a $750 posted above. Thanks
Old Jan 30, 2007 | 01:46 PM
Bonshawman's Avatar
I have my Pac Brake (have a Jake on my big Peterbilt...) on my 05 4x4 CTD 6spd - love it ! Works seamlessly with the cruise control, slows down my rig which weighs in on a recent trip from South Florida - Arkansas - South Florida @ just under 23K - don't even worry if the trailer brakes have an issue. Heck, I even run it when I'm toolin' around town - love that sound, and it also means that often I don't have to down shift - way cool ! Good luck with either !
Old Jan 30, 2007 | 03:11 PM
ptgarcia's Avatar
Is the Pac Brake PRXB worth the added expense over the standard Pac Brake? And what's the difference between the two?
Old Jan 30, 2007 | 03:41 PM
darrenb's Avatar
where are you guys finding the pac brake for $750? ebay has one at $1190......
Old Jan 30, 2007 | 03:44 PM
MRoman's Avatar
I have the Jake, had it installed by the dealer before I picked up the truck. I use it all the time, not just when pulling a trailer. It's great, hardly ever use the service brakes to slow down. I did read somewhere on this forum that the Pac holds better when pulling heavy. I only pull 7K so it's good enough for me.
