Timing rattle??? HELP!
Old Apr 1, 2007 | 02:12 AM
acook's Avatar
I was takeing my friend for a ride in my truck today and he was very impressed. I was telling him if i put my bully dog back to stock it still drove good with almost no smoke, so later on i put it to stock and going from a stop and getting into it i would have a slight ratte for 2 seconds or so and then it would quit. We did this 3 times, hes a truck driver and said it sounded like timing rattle. I switched it back to CL and i didnt hear it anymore? This is really making me paranoid and i have to drive 130 miles back to school tommorow so whats going on? I forgot to mention my edge EZ was on 1 the whole time. He said that maybe with my injectors and twins on a stock setting the timing was to retarded but wasnt quite sure??
Old Apr 1, 2007 | 02:56 AM
morkable's Avatar
Very good chance that you got some bad fuel, put some good conditioner in it, such as powerup, (something with lots of cetene in it) After another tank it will probably clear up
Kevin
Old Apr 1, 2007 | 03:03 AM
acook's Avatar
well it stoped after putting the CL back in and i have power service in it? Im just confused...and really freaked out about my truck going kaboom.
Old Apr 1, 2007 | 06:57 AM
MikeyB's Avatar
Sounds like a problem with the programming. I would contact Bully Dog.
MikeyB
Old Apr 1, 2007 | 10:58 AM
973604x4's Avatar
when i am driving on stock power, at higher RPM's i hear a slight rattle, especially bad when my EZ is on. what i am talking about is short lived, as soon as the tranny shifts the noise is back to normal.
My truck did it 5 or 6 times yesterday driving on stock power with my bigger turbo. I think its more injector noise than anything. you put CL back on and its fine, so oh well. Mine always acted the same....put more fuel into it and no noise, kinda like it was runnin too lean. oh well. drive back to school with no worries
Old Apr 1, 2007 | 03:38 PM
cquestad's Avatar
Bad programing with the BDDL...maybe like the "Luken" sydrome?
Old Apr 1, 2007 | 07:01 PM
abc4yew's Avatar
ACook, our little plan is working....just kidding....If it went away with the CL then don't worry about it. Sounds like your truck is addicted to power and when you go back to stock the ECM goes to toopid. ks
Old Apr 1, 2007 | 10:10 PM
morkable's Avatar
Mine will do it every so often. But as I said, it is usually if I dont put in enough of the power up. Or if I use a different brand. I have found that the power up IMO has the most cetene per 100ml that I can find.
And what really makes that weird, is sometimes it will go away if I put the edge to 5
Kevin
RonP
Apr 2, 2007 12:25 PM
templer
Jan 24, 2007 12:16 PM
Buffalo
24
Jan 3, 2006 05:28 PM
foley
Jun 1, 2005 03:54 PM
