timing on an 04
Old Feb 27, 2011 | 09:17 PM
tweeter123's Avatar
timing on an 04
i hear peole talking about resetting the timing on there diesel i was wondering about if and how that helps i tow horse trailer and tractors often mainly curious if it helps at all thanks
Old Feb 28, 2011 | 01:00 PM
JJPage's Avatar
To change the timing on your 04, you need a programmer....You can advance your timing(without a programmer) a few degrees, by either purchasing a Rochtec crank sensor to replace the factory unit, or by doing the "tone ring mod". You can do a search for the tone ring mod, pretty simple really, basically remove the tone ring and "oval" out the alignment pin hole 1/8" to the counterclockwise direction while standing in front of your truck, re-install keeping the alignment pin in the new position.
The increased timing will give you better lowend throttle response, and will help mileage a tad.
Old Feb 28, 2011 | 01:15 PM
AH64ID's Avatar
As for programmers the Smarty Jr has the best timing for the CR.
Old Feb 28, 2011 | 07:55 PM
tweeter123's Avatar
ok i kinda regretted buying a predator after learning what all a smarty can do can you do timing with a predator and about how long does the tone ring mod take im going to look it up thanks for the replys
Old Feb 28, 2011 | 08:15 PM
JJPage's Avatar
I am not very familiar with the Predator, but am fairly certain it has advanced timing in it's programming software.
The tone ring mod took me about an hour and a half, but with a programmer it is not necessary and could cause too much timing by using both, mine is now back in the original position.
GR40RCapri
Jul 24, 2006 11:47 PM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
