Time to switch from SuperChips to???
Old Feb 26, 2008 | 09:20 PM
Derek Timm's Avatar
Well I've been running the SUperChips prgrammer for about a year now and it's not bad but I don't like the EGT's when towing and I sure could use some mileage.
Any one who had a super ships what did you go to and how did it work out?
Derek <*)))><
Old Feb 26, 2008 | 09:24 PM
Pinksa's Avatar
Ive never owned a Superchips, but i know alot of people have gone to the SMARTY. Has my vote
Old Feb 26, 2008 | 09:26 PM
lmills's Avatar
try the smarty. you will love it!
Old Feb 26, 2008 | 09:27 PM
Derek Timm's Avatar
How dose the smarty work with no big mods?
Derek <*)))><
Old Feb 26, 2008 | 09:41 PM
jmccart's Avatar
I went from a superchips, to a Diablo, back to the Superchips, to a Smarty Sr. Smarty is great, either with no other performance parts or a full pile of receipts.
Smarty Jr is good if you want to stay mild and not fry your clutch. It will have a resale within like $50-$75 of what you pay for it in case you ever decide to get silly.
Good luck buddy.
Old Feb 26, 2008 | 09:43 PM
lmills's Avatar
Yes Derek,
the smarty works great on stock trucks. It totally changes the feel of the truck. Definitely on the list of best mods I did.
Old Feb 26, 2008 | 09:49 PM
Derek Timm's Avatar
Just got my new SB con ofe so I can dump my dual mass junk, just need to install it.
How are temps using the 170 hp setting? Anyone towed at the 7/8/9 settings?
I will be reading and searching a lot of old smarty posts!
Derek <*)))><
Old Feb 26, 2008 | 10:18 PM
jmccart's Avatar
If you get it from someone who has not had it on a shelf for a while, so it has the latest tune, the temps are a bunch cooler (150-200*) than the Superchips. I was shocked at how much cooler my truck ran. WHen I first loaded the Smarty, it had an older tune and it smoked like crazy. Then I loaded the latest download (Dec. 07) from the website, and smoke levels are really low and EGT's totally dropped.
Now I am running the 4.4 beta, it is still cooler than the Superchips, but hotter than the standard Dec. 07 download.
Old Feb 26, 2008 | 10:38 PM
Derek Timm's Avatar
Nice to hear about 150 or more cooler on the EGT's.
Any fueling issues draining the rail with the stock CP3/injectors/turbo and the higher settings?
Derek <*)))><
Old Feb 26, 2008 | 11:55 PM
trx's Avatar
trx
I use the smarty for towing all the time works great egt's in check i just dont get out of hand with it when i've got a load behind. On higher settings you may need a better fuel pump to keep up, not sure but without a pressure box i doubt I am draining the rail with my set up. Go Smarty you wont be dissapointed!
Old Feb 27, 2008 | 01:36 PM
Derek Timm's Avatar
Looks like all of the replys and research are definitly pointing to a new smarty.
The I'll have to do a wallet check to see the other goodies that will bump me up a level.
BTW any comments on mileage with stock truck and the Smarty and on what setting and program revision?
Derek <*)))><
smokeyram
Aug 21, 2009 06:19 PM
Barryn
Jul 14, 2008 09:30 AM
SPLnut
Dec 31, 2007 11:27 AM
HOdiesel80
Mar 22, 2007 12:19 PM
redramnc
Mar 28, 2005 06:58 AM
