thoughts on the banks Big Hoss Bundle
Old Dec 11, 2006 | 04:12 PM
turbosonoma's Avatar
its cheap
it has everything
and its the same for 07
thought, opinions or better ideas?
Old Dec 11, 2006 | 04:15 PM
CDoskocil9's Avatar
I wouldnt if your going for big power...................... And what do you consider cheap????
ptgarcia's Avatar
Cheap?.....can I be your friend?
Old Dec 11, 2006 | 04:20 PM
its supposed to make decent enough power isnt it?, this thing needs to be driveable, but if i did decide to get a bit more indepth later on it would be nice if what i have already done will be sufficient for more ad ons.....
its 2935 shipped
Old Dec 11, 2006 | 04:24 PM
ptgarcia's Avatar
its 2935 shipped
It makes about the same power as my $400 Xzillaraider...
Trust me, you can get so much more for so much less. Grab a cold one and some chips, do a search and start reading. Then when you're thoroughly confused come back and ask again...
Old Dec 11, 2006 | 04:29 PM
dodgezilla04's Avatar
what portion of the country do you reside? maybe a member close to you can visit and let you 'borrow' a module to let you see just how much power you can get for under $500.
Old Dec 11, 2006 | 04:45 PM
yeah but isnt it also all about being "efficient" and having the right egt's and making the truck last?? im real new to this whole diesel bit so i havent a clue, i know just cranking up the boost on my gas turbo truck isnt generally the best idea as everything else sorta has to be in place too so itll all be efficient together......
Old Dec 11, 2006 | 04:55 PM
CDoskocil9's Avatar
Granted it is a good idea to improve air flow but for 2900 dollars you can get alot of air lol...........................
Old Dec 11, 2006 | 04:56 PM
CDoskocil9's Avatar
By the way I have the six gun and PDA, it is a good system and does what is adverised to do, it was just expensive............
Old Dec 11, 2006 | 04:58 PM
ptgarcia's Avatar
My Commander and Xzillaraider make great power and are packed full of monitoring and safety features. Combined with a free flowing exhaust (I added an MBRP muffler and left the stock 4" pipes) and maybe an intake (I don't have one) I'm sure I run every bit as cool as the Banks kit. Just so you know, none of the power adders recommend towing on the highest power level. Most recommend it on the lowest or 2nd level.
Old Dec 11, 2006 | 05:04 PM
with my race module, intake, exhaust, LP AND turbo, i am still below the price of that bundle, and i believe that I generate more power, lower egt's,and have the usable power as well.
but all that red stuff looks pretty.
Old Dec 11, 2006 | 05:28 PM
SehrleBD's Avatar
I know this is a dumb question but do you care at all about your warrenty?
Old Dec 11, 2006 | 05:32 PM
not really, if it breaks im sure its fixable.
mind you the intentions are not to try to break it
Old Dec 11, 2006 | 05:38 PM
CDoskocil9's Avatar
turbosonoma check your PM's
Old Dec 11, 2006 | 05:48 PM
nelrod's Avatar
The beauty of a diesel is you don't have to spend 3000 to get an awsome amt of power. You may have to spend that and more to get not even as much torque or power on a gas engine. Read a lot and go talk to a diesel performance shop. I have Commander that moniters fuel pressure, Rail pressure, oil temp, water temp, boost, and egt, and quad race box 140 hp and a ? bunch more torque, for less than 1000 bucks. I have some banks stuff on my 6.9 ford, but it is overpriced. reseach, talk to some diesel shops and you will find for 3000$ you can get a lot more bang for your buck.
Good luck.
