Things we learned on the Dyno & 555 HO
Originally posted by Jannetty Racing
Alot of times they are UP TOO numbers and not telling the whole story.
I can attest to that statement
. All of your logic and explanations (both here and there) sound right on to me. Thanks again for posting the info. I realize you did not have to share this information.
taken from DLeno
But the ECM reads MAP, not boost (boost is the pressure difference between the intake manifold and the outside air). Whatever air pressure is present at the MAP sensor is what the ECM will react to.
The ECM also gets an input from the combination Inlet Air Temp/ Pressure Sensor located in the air cleaner box. That sensor measures true ambient barametric pressure and would decrease at altitude. Isn't it possible that the ECM is subtracting that pressure reading from the MAP reading and is reacting to the difference which is boost? Wouldn't that result in a truck at high altitude also being effected (at least to some degree) by the over-boost/defueling condition that Ted is talking about?
The Boss Hog
(just an idea . . . .
Can someone provide detailed instructions on the wategate adjustment? Like Chadrock I am not ready to invest in a box, yet would like to realize the full benefit of the opened up exhaust and intake.
From: Drive till ya hit a Polar Bear, then go back 50 miles
Then you WILL realize the advertised benifits of Air filter and exhaust.
We usually don't see a negative like that though. I'd suspect that the wastegate hasn't been adjusted correctly from the factory, and the truck is indeed being driven into defueling by a slight overboost condition.
On the air side of the equation, however, we have seen boosts in mid-range power on the dyno with a variety of air systems. The higher the elevation, the greater the boost in power due to the IAT/AP sensor on the airbox. Of course, a poorly adjusted wastegate will negate those gains as the 03 ECM compensates for the additional boost.
Rod
So the moral of this story is...buy a box of some sorts that fools the boost.
I'm off to purchase my 4" exhaust now that I've my EZ and eagerly awaiting the call from Rod or Scotty to tell me they've found my long awaited Scotty III air assembly for my, ooops, I mean my wife's truck!
klx650a2
17
Mar 2, 2009 12:38 PM
satburn
Competition / Pulls / OffRoad
29
Oct 2, 2007 10:16 AM
flypigs
Aug 1, 2007 09:04 PM
Dufrain
22
Dec 23, 2004 09:24 PM
