Are they big enought
Old May 1, 2008 | 07:57 AM
Jethro6213's Avatar
Are they big enough
I have a set of II towing twins for my '03. I am going to be running Flux 3's and dual pumps. Will the 62/K31 set up be big enough? Or should I sell them and go bigger. Is it possible to put a S400 in place of the K31 without having to do alot of modifications? Thanks
Old May 1, 2008 | 10:43 AM
chrleb1's Avatar
What programming or boxes are you running also? It really depends on how much fuel you are feeding to those injectors with programming or boxes. With mild programming, it'll be ok the way it is. If you are going to run a Smarty and TST with those injectors( or something close), then swap in the S400.
roughstock
Apr 21, 2008 10:44 PM
dieselfreak21
Aug 29, 2007 10:03 PM
FortMacSummit
19
Jan 19, 2007 09:32 PM
whazzup
Jun 17, 2004 08:25 AM
