Temperature Observations
Old Jun 3, 2006 | 11:14 AM
TonyB's Avatar
So, I got the gauges installed & learning what the normal trends are. Consequently, I have a few questions / observations. Every reading I have is unloaded at thsi point.
Auto Meter Factory
Water 172F 200F
Trans 170F --
Oil Pres 20 40 (idle)
Oil Pres 70 >40 (2500rpm)
Fuel Pres 10 (idle)
Fuel Pres 6 (WOT accelleration)
Boost 32 (WOT FWY, passing)
Pyro 1200+ (pre-turbo, WOT)
Pyro 600-800 (cruising fwy/city)
Pyro <400 (shutdown)
Is the water temp always so steady? Overnight, it'll cool down to ~160F, but then again overnight temps cool down to 75F; during the day, we are hitting 110F lately.
When I started this morning, trans temp was ~160F & warmed up to 170F, near water temp.
I realize there is a LARGE mass of cast iron and water to heat & cool. But, are these temps kinda normal?
TIA
Tony
Old Jun 3, 2006 | 08:34 PM
bigwheels94's Avatar
If you mean that your water temp never goes below 165*,then your gauge/sender is faulty.It doesn't matter how warm it stays overnight.After 8hrs.sitting in the drive way the engine/trans,etc. will be at ambient temp,or less.All of my rigs will be at ambient temp when I go out to start in the morning.Get an infrared temp gun,& check it out.
Haulin_in_Dixie
Sep 27, 2003 01:24 PM
turbov6joe
14
Aug 29, 2003 09:29 AM
dieseldel
20
Aug 15, 2003 11:25 AM
