Tank vent mod.
I capped mine off and had a BAD pressure problem when opening the fill neck. I then connected the two and routed them up in to a frame and installed a cheap in-line fuel filter, pressure problem cured plus some amount of filtration.
Like Nascarcamper said,
I also hooked the two vent holes together with a T and routed the hose as high as I could with a fuel filter on the end to keep the junk out.
welndmn
Jul 10, 2007 07:51 AM
TPilaske
21
Aug 15, 2006 01:56 PM
ramtd02
19
May 4, 2006 10:17 PM
Brad02ctd
17
Apr 27, 2006 12:28 PM
