Symptoms of tranny hunting.......I may have it
Old Sep 25, 2008 | 11:15 PM
kanuckle head's Avatar
I talked to DTT a few weeks ago and they offer a electronic shift enhancer that can cure the shifting mishap
my question is has anyone used this product to solve this shifting problem
Old Sep 26, 2008 | 07:56 AM
HOV's Avatar
HOV
I found my tranny was hunting when he started dropping off dead animals at my door.
ON a more serious note, I have a 2-3 hunt and would like to try the DTT shift enhanser to eradicate the problem
Old Sep 26, 2008 | 09:02 AM
cincydiesel's Avatar
I have a shift enhancer and it does help but it sure dont cure it. Worth the money IMO though
Old Sep 26, 2008 | 12:17 PM
Justice4all's Avatar
The shift enhanser doesn't tune the shift programming. It gives you programmable line pressure and pressure rise, and it seems to work pretty well.
It would require a programmer that could get into the PCM to completely alter the shift programming. There are tricks you can do to the VB to fool the programming mechanically, but that is a fix to the symptom and not really a fix to the whole problem.
Old Sep 26, 2008 | 12:27 PM
BPoulsen's Avatar
Mine goes in on Monday for this - the TSB ( 21-009-07 ). And for the broken recirc door ( again ). I'll keep you updated on if the TSB works.
Old Sep 26, 2008 | 12:28 PM
The TSB should fix a 1-2 hunt, but it won't fix the 2-3.
Old Sep 26, 2008 | 01:04 PM
EDR's Avatar
EDR
I had the 1-2 hunting issue and while it took three visits to the dealer to get them to finally "recreate" the problem. Once they were able to get it to "hunt" they did perform the TSB, and it has fixed the issue.
I don't know about your dealers, but I had to get specific on when it would happen, including the truck's speed (15 MPH +/- 3 MPH), transmission temperature (both cold and normal operating temps) and the situations when it occurred (loaded and unoaded).
Until I finally held their hands and walked them through the problem, they couldn't figure it out. Sorry for venting, but it continually amazes me how poor customer service has become.
Old Sep 26, 2008 | 01:54 PM
BPoulsen's Avatar
Justice - good point - as of yet, I don't have the 2-3 hunt, or haven't noticed it.
Old Sep 27, 2008 | 02:34 AM
I spoke to my tranny builder he gave me to various scenarios to try
it would seem that this is a common problem on the 05 and up dew to that line pressure & shifting is controlled electronically.........which I believe him saying the TCM ?
One of his solutions was to disconnected all the battery terminals & touch the pos & neg cables for 15 mins to reset the ECM
Then reconnect the cables and drive the truck the same throttle when the hunting occurs to correct & relearn it self
But he also said the problem will eventually return
The other suggestion was to get the dealer to re flash the system, like that of EDR's ...............in hopes that my dealer is more cooperative than his
Bottom line is I think DODGE dropped the ball on this one because it seems to be an epidemic
Old Sep 27, 2008 | 04:15 AM
98whitelightnin's Avatar
I also had a similer problem and it was the battery so maybe clean your posts and tighten the clamps down good, plus it wont cost you anything.
Old Sep 28, 2008 | 12:16 AM
You're absolutely right! Not to badmouth Dodge because I love the truck, but they really need to address the PCM programming on this issue. The 2-3 hunt is a very common problem.
Old Sep 28, 2008 | 01:27 PM
sallyman1's Avatar
know your tranny is hunting if it starts wearing bright orange or camoflauge jackets?also check oil pan for a winchester or remington trace
notpowerSTROKIN
Nov 5, 2007 07:35 AM
madhat
May 26, 2007 10:58 PM
Bart Timothy
May 4, 2006 04:53 AM
