Symptoms of tranny hunting.......I may have it
Old Sep 24, 2008 | 10:18 PM
kanuckle head's Avatar
Can any one give me tell/tale of transmission hunting
I was told that it was common on 05 CR's
It seems to be more noticeable when I'm under load, towing and light on the throttle
From my description on the shifting pattern it shifts up and in a split second down then up again.......DRIVES ME BANANAS
I was told by a few respectable tranny shops that it may have something to do with my VB & may need to be replaced
Would like to know if other members had this problem and any other ways to solve it
Old Sep 24, 2008 | 10:42 PM
cbrahs's Avatar
is it haunted or is it Hunting?
Old Sep 24, 2008 | 10:48 PM
cbrahs's Avatar
I see trany's hunting more if people have larger tires on the truck. Mine does it, the dealer replaced the solenoids and it fixed it for about 1500 miles and it is back. Mine did it when i was at partial throttle, driving slow like in a neighborhood. drives me nutty but I am waiting for the $$$ to replace the tranny and just pull the trigger on a full billet unit.
Old Sep 24, 2008 | 10:51 PM
a ghost shifter in my trany
Old Sep 24, 2008 | 10:57 PM
I was also told that it was may be my 35 in rubbers but on one fishing trip hauling the boat & camper on the west coast billy goat trails I had my stockies on and no change on the hunting
Old Sep 24, 2008 | 11:02 PM
STate's Avatar
I had hunting between 1st and 2nd under light accel. and it ended up being a bad shift pressure solenoid. Had it replaced and no more hunting. This was on my stock 48re.
Old Sep 24, 2008 | 11:08 PM
cbrahs's Avatar
have the solenoids replaced and a tranny service. Should be good to go.
Old Sep 24, 2008 | 11:18 PM
RedRacer44's Avatar
My truck was doing it the exact same thing....talked to my neighbor who is a Cummins tech. He said that there is a TSB for the shift pressure solenoid but it doesn't always "cure" the problem at least from what he's seen....
What we did on my truck was adjust the throttle or kick-down cable (whatever you want to call it) and now my truck shifts like a dream. Basically it fooled the truck into waiting just a touch longer to shift...now I don't have the sloppy shifts and no 2-3-2 gear hunt...just smooth/firm shifts all the way through the gears....
Old Sep 25, 2008 | 10:06 AM
kantdrive55's Avatar
DTR Advertiser
If the TSB reflash doesnt fix the issue which in about 60% of all cases doesnt, we have a change in our valvebody that corrects the hunting problem. This is a very common problem that mainly shows up in the 05.
Old Sep 25, 2008 | 11:43 AM
Justice4all's Avatar
One way to remedy the problem, or to keep it from driving you nuts is to push the accelerator pedal to 35 MPH and then slow down from there. This is what I do most times. If traffic is tight I space back a little for room to moderately accelerate to 35 and then slow down.
Also, these transmissions don't seem to do it in tow/haul, so if you feel comfortable running in tow/haul it might just be the answer for you.
Old Sep 25, 2008 | 11:47 AM
cincydiesel's Avatar
I was told it was the shift program in the ECM by Dave at Goerends. I hate the 3/4 T/C lock up on my truck. Talk about a shift
Old Sep 25, 2008 | 04:16 PM
bradmizer's Avatar
My 07 does it when i accelerate giving it about 3/4 throttal it kinda jumps around till it hits 3 gear, it also does it at about 25 mph it umps from 2 to 3, anyone know what my problem could be?
Old Sep 25, 2008 | 07:25 PM
RRC's Avatar
RRC
Mine just seems to hold third for a LONG time unless you are 3/4 or more into the throttle, hmmmm...
Old Sep 25, 2008 | 08:35 PM
mudder500's Avatar
1 to 2 and 3 to 4 hunting of the gears. Its on his way out. Buddy at dodge is taking care of it
Old Sep 25, 2008 | 09:27 PM
This is true, unfortunately there are no boxes to tune the shift programming.
