Swiss Cheese Air Box
Do you notice any difference (performance, spooling up) after adding the holes?
I see you sig says you have an AFE? Any thoughts if this helps one way or another, or can you tell if any change is due to the AFE or the holes. thats probably way to many questions.
Administrator/Jarhead
Check out my pics, or this post...
https://www.dieseltruckresource.com/...iy+air+box+mod
This is the way I did it, many other ways to do it. Just my .02.
i can't tell any diff. between the box with holes (airaid filter) & the cold air intake (k&n).
i usually will swap out between the two when it's time for a cleaning, doesn't take much time
Hardware store mod
L8r,..............dogger
I second the cold air idea. I learned from a member here. I installed a 4" toilet flange in the bottom of the airbox and then ran a dryer duct hose to the front bumper just behind the fog lamp.
Since then, my filter minder does not suck down when I pull a load like it did when it was stock. That is plain proof that it is now getting the air it needs.
My minder hasn't moved down any since I put in the Amsoil Nanofiber dry drop in filter. Seems this would mean it is getting enough air? Or should I also swiss cheese bottom of box?
Actually, ladies Nylon is VERY restrictive, at least the piece I used on my old '86 Z28 was. The car was equipped with a Mass Air Flow meter, and I pulled the air filter and box completely off, and put a piece of ladies nylon over the meter, and the car barely ran. The nylon was choking off the air supply to the motor. That was my experience with ladies nylon and cars. Granted that was 16 years ago, so with today technology, ladies nylon maybe better breathing
